Authenticate API using n8n and AWS4 signature
I would like to use the Orderhive API, but it is using an authentication method I haven’t used before based on AWS4 signature. Is there a simple way to do that authentication using the HTTP request node, or should I use the Code node instead? I am not a coder so any solution to make it simple would greatly help :slight_smile:
Please share the workflow
(Select the nodes and use the keyboard shortcuts CMD+C/CTRL+C and CMD+V/CTRL+V to copy and paste the workflow respectively)
  • n8n version: 0.210.2
  • Database you’re using (default: SQLite):
  • Running n8n with the execution process [own(default), main]: own
  • Running n8n via [Docker, npm, n8n.cloud, desktop app]: n8n.cloud
Hey @VinceRocher,
Using the code node might be the best way to handle it although it looks like there might be a fair amount of work needed to get it going.
Then again… if it uses AWS signatures maybe you can add your credential as an AWS account in n8n and try using that from the http request node.
