Hey,
I’m reaching out because I’ve run into an authentication snag with the Snowflake node in n8n. Whenever I try to set it up, I’m hitting a username/password error, even though I’ve double-checked to make sure all my settings are correct.
OperationFailedError: Incorrect username or password was specified.
at createError (/usr/lib/node_modules/n8n/node_modules/snowflake-sdk/lib/errors.js:538:15)
at Object.exports.createOperationFailedError (/usr/lib/node_modules/n8n/node_modules/snowflake-sdk/lib/errors.js:326:10)
at Object.callback (/usr/lib/node_modules/n8n/node_modules/snowflake-sdk/lib/services/sf.js:684:28)
at /usr/lib/node_modules/n8n/node_modules/snowflake-sdk/lib/http/base.js:125:26
at processTicksAndRejections (node:internal/process/task_queues:95:5)
Here’s the deal: I usually access Snowflake via a corporate platform with single sign-on (SSO), which means I don’t have to log in to Snowflake again once I’m authenticated on our main platform. Therefore, within the n8n’s Snowflake node, I’m using the credentials from our corporate login, as those are the only ones available to me.
I’m wondering if there’s a mismatch between the SSO credentials and what n8n’s Snowflake node expects. Any insights on how to configure the node to work with this type of SSO authentication setup? Any tips or similar experiences would be really helpful.
Thanks for your assistance in advance!
Best,
A.J
- **n8n version:1.11.1
