I have integrated responses from an llm, in a n8n workflow. Now these variables I have to set them in a google docs, but given the structure of this one, I can’t auto adjust the format and then I always have to end up adjusting them manually. Do you know any method to make this 100% automatic and to auto set the variables?
- n8n version:
- Database (default: SQLite):
- Operating system:
Hey @antonio_resoluciona,
Can you share a small example that reproduces the problem you are trying to solve and some test data we can then use that to see what we can do.
