Auto Categorise Outlook Emails with AI Using N8N
Discover how to streamline your email management with this comprehensive tutorial on setting up my Auto Categorise Outlook Emails with AI N8N Template! :e-mail::sparkles: This video takes you through every step needed to build an efficient automation system, from configuring a static domain using ngrok to integrating with Microsoft’s Azure to authenticate Outlook services. We’ll show you how to set up N8N locally using Docker on Windows Subsystem for Linux (WSL) and connect it to Ollama’s AI models for precise email categorisation.
By the end of this guide, you’ll know how to use N8N to automatically sort and tag your emails based on their content, saving you hours of manual effort and making it easier to manage large volumes of correspondence. We’ll also cover how to refine the workflow with AI prompts, manage JSON outputs, and deal with any exceptions to ensure your automation runs smoothly. If you’re a business professional looking to simplify your inbox or are aiming to automate tasks, this tutorial has everything you need to master N8N for Outlook email automation. :wrench::incoming_envelope:
Make sure to explore the N8N Creators Hub for the ready-made template used in this video. Download it and start categorising your emails with ease! Links are in the description below. :link:
Download the template here
@bartv thank you Bart! I was just heading to post this but I’m glad you beat me to it :slight_smile:
Ha, sorry about that %^) I’ll update the author of the post to you - feel free to edit as you see fit.
Hey @Wayne amazing workflow one thing i face when testing it the set category doesn’t work you need first to create category manually inside outlook it can’t be dynamic
can you please check i’m still a new
Thank you for your efforts
