Automated Blog Publishing Workflow Using n8n – Need Help to Humanize AI Content
Hello n8n Community
I’ve built a custom workflow in n8n that fully automates the blog publishing process. Just by inputting a topic, number of chapters, and target audience, it generates the content (along with relevant images) and directly publishes the blog to our website.
While the automation works great technically, there’s one issue:
The content generated is easily flagged as AI-generated by detection tools, which is not ideal for SEO or Google rankings.
My question:
What are the best methods or tools to humanize AI-generated content so that it reads more naturally and isn’t easily detected as AI-written?
Any suggestions, strategies, or tools that worked for you would be highly appreciated!
In my opinion, this is an issue that you can currently detect using mechanism X, but then the tools become outdated, and the issue continues.
My recommendation: If your goal is to create content, AI can help you develop the idea, but you have to intervene to convey the feeling you want to convey to your audience, generating images in the same way.
When I program the publications of the week, I take the ideas, write what I want, use AI to clarify the idea but in the end everything and I do things in my style, everything can be automated but there are things that cannot.
you can try https://undetectable.ai
Appreciated.
I had the same issue making AI content sound less robotic. I started running my drafts through Humanizer AI before publishing and it really helped make things feel more natural.
It smooths out weird phrasing and adds those little human touches. I just use a simple HTTP node in n8n to send my text to Humanizer AI and get the cleaned-up version back before pushing to the blog.
Just trying to figure this out myself now. Im currently testing undetectable.ai and not yet sure what the best way to implement it would be. My content writing automations are quite complex, 4 agents linked together, including one “editor” agent who’s job it is to humanize based on my own criteria. Im thinking to put http request node in as a tool for this agent and let is check AI detection score at sentence or paragraph level. Also considering giving the API the full content but this throw in other problems like preserving links etc plus costs.
Appreciated.
I actually integrated Clever AI Humanizer https://aihumanizer.net/ into my n8n workflow last month. It’s pretty solid - way less robotic than raw ChatGPT output, and my engagement improved.But it’s not perfect. Still struggles with Originality.ai detection, and some synonym choices feel off. I usually need to polish the flow manually anyway. Also, no tone selection options which is annoying.Processing takes 10-20 seconds per article, and you need paid API access for automation. Worth it overall, but don’t expect plug-and-play perfection!
I’ve encountered the same challenge when automating blog content. Most AI generated texts get flagged, which hurts SEO. The best tool I’ve used to fix this is GPTHuman AI. It’s currently the most effective AI humanizer in my experience. It rewrites the content in a way that feels natural and human-written, while still keeping the original meaning intact. After processing my blog drafts through GPTHuman AI, they not only pass AI detection tools but also read more smoothly and engage readers better. Highly recommend adding it to your workflow for cleaner, undetectable outputs.
I’ve been running my draft paragraphs through AI Detectors lately, and using the tool there really helped me keep my tone natural without messing up my keywords. I like that it keeps my uploads private and lets me save past versions, so tweaking things feels a lot smoother.
