Automated Web Ingestion Pipeline in n8n for LLM Knowledge Bases & RAG (75% Token Reduction + WAF Bypass)
Hi everyone! :waving_hand:
I put together a practical architecture pattern for automating web scraping and knowledge base ingestion in n8n without getting blocked by Cloudflare/anti-bot WAFs and without polluting the LLM context with heavy HTML.
### Architecture Overview
[Schedule Trigger] ➔ [Read Target URLs] ➔ [HTTP Node: MESSORA API] ➔ [Embeddings] ➔ [Vector DB / Pinecone]
### The Problem it solves:
1. **WAF/Anti-bot blocks**: Standard HTTP nodes or headless browser nodes fail on sites protected by Cloudflare or DataDome.
2. **Token waste**: Passing raw HTML through LLMs consumes huge context windows. Clean Markdown reduces token load by ~75%.
### How to configure the HTTP Request Node in n8n:
- **Method**: `POST`
- **URL**: `https://api.messora.dev/v1/extract\`
- **Auth**: Generic Header Auth (`Authorization: Bearer YOUR_MESSORA_API_KEY`)
- **Body JSON**:
```json
“url”: “={{ $json.url }}”,
“only_main_content”: true
The response returns clean Markdown under data.markdown ready to feed directly into text splitters and embeddings.
I wrote a detailed step-by-step tutorial with sample JSON workflows here:
:backhand_index_pointing_right: Full Guide: Building an automated web ingestion pipeline in n8n for LLM knowledge bases - DEV Community
Hope this helps anyone building RAG and AI workflows in n8n! Feedback and questions are welcome.
