Hi, We’re looking for a practical n8n builder to help us design and maintain production-grade workflows.
This is ongoing work on real systems (not one-off zaps, not experiments).
The work
You’ll be building and maintaining n8n workflows that:
• Integrate APIs (REST, webhooks, OAuth)
• Handle pagination, retries, rate limits
• Deduplicate safely (idempotency matters)
• Send alerts only when something *actually* fails
• Are readable and maintainable over time
There’s room to help shape the logic, not just wire nodes.
What we’re looking for
You’re likely a good fit if:
• You’ve built real workflows in n8n, not just demos
• You’re comfortable inspecting execution data
• You think about edge cases and failure modes
• You’re happy working async
• You’re based in Europe (time-zone overlap)
I’m really interested in this opportunity. I’ve been in the industry from 3+ years worked with over 20 companies across the globe and build practical scalable production level workflows. I’d love to do the test project.
I’m a German based IT Consultant and prior Head of IT for a D2C e-commerce company. I know n8n since release and did build some expertise around it over the last year. Prior to my automation consultancy work I was administrating a wide range of E-Commerce related systems like ERP’s (Bueroware), CRM’s (Hubspot, Salesforce), Webshop Systems (Oxid & Shopify), Payment Provider API’s (Unzer) and many more.
This gives me great insight into business processes and a good first idea on how to automate specific tasks.
I got you, I have been building all forms of automations for the past 2 years and have built 100s of flows for my clients. Have worked with all sorts of companies and gotten them 10s of thousands in revenue or savings by strategic flows. When you decide to work with me, not only will I build this flow out, but also give you a free consultation like I have for all my clients that led to these revenue jumps.
I have built a similar workflow like this for one of my clients. I can not only share that but also how you can streamline processes in your company for faster operations. All this with no strings attached on our first call.
Here, have a look at my website and you can book a call with me there!
Hey, I’m AK. I build and maintain production n8n systems for real businesses (voice agents, CRM + ops pipelines, lead systems, etc.). I’m n8n Level 1 & 2 certified and a Verified n8n Creator, and most of my work is about keeping workflows stable over months: clean architecture, predictable failure handling, and “don’t wake anyone up at 3AM unless it’s real” alerting.
I typically design workflows with clear modules and practical monitoring so alerts are actionable (not noisy). I’m happy working async and I’m open to the paid test task.
If helpful, share what systems you’re integrating (e.g., Stripe/CRM/internal tools) and whether you need more net-new builds or ongoing maintenance, then I can confirm fit quickly.
P.S: I’m in IST timezone and I can align working with your timezone.
I’m Muhammad Bin Zohaib, an individual n8n Automation Systems Builder working on production-grade workflows (not demos or one-off zaps).
I regularly build and maintain n8n systems that:
Integrate REST APIs, webhooks, OAuth
Handle pagination, retries, and rate limits
Implement safe deduplication & idempotency
Send alerts only on real failures
Stay readable and maintainable long-term
I’m comfortable inspecting execution data, designing for edge cases, and maintaining long-running workflows. I also enjoy helping shape workflow logic rather than just wiring nodes.
Availability
10–30 hrs/week (async-friendly)
Happy to do the paid test task
Ready for a long-term collaboration
Relevant background
AI & Automation Engineer working with agencies and product teams
Experience with CRMs, Stripe, internal tools, and custom APIs
Thanks for the clear description — this is exactly the type of n8n work I focus on. I’m a practical n8n workflow builder with experience designing and maintaining long-running, production-grade automations, not one-off zaps or demos.
Below is a concise overview of how I fit what you’re looking for.
Profile Summary
n8n-focused Automation Engineer with 4+ years of real-world experience
Strong emphasis on reliability, readability, and long-term maintenance
Used to working async with distributed teams
Based in Europe with full time-zone overlap
How I Build Production Workflows
API integrations
REST, Webhooks, OAuth
Pagination (cursor & offset-based)
Rate-limit awareness and backoff strategies
Reliability & safety
Idempotent design (safe deduplication)
Explicit retry logic and circuit breakers
Alerts only on actionable failures
Maintainability
Clear naming and modular workflow structure
Centralized config and credentials
Execution data inspection and root-cause analysis
Operational readiness
Logging, error routing, and failure recovery
Designed for long-running and repeat executions
Low-noise monitoring
Relevant Case Studies
Case Study 1: API-Heavy Data Sync
Built n8n workflows syncing data between multiple REST APIs
Handled pagination, retries, and deduplication via external IDs
Implemented fail-only alerts with contextual metadata
Result: Stable daily runs with zero duplicate records
Case Study 2: Payment & CRM Automation
Integrated Stripe-style payment events with internal tools and CRMs
Designed idempotent webhook handlers to avoid double-processing
Maintained workflows over time as schemas evolved
Result: Reliable financial event processing with minimal maintenance
Case Study 3: Long-Running Operational Workflows
Maintained workflows running continuously for months
Used execution inspection to diagnose edge cases and silent failures
Refactored legacy workflows for readability and resilience
Result: Reduced error rates and improved debuggability for the team
Why I’m a Good Fit
I treat workflows like software, not “automation glue”
I think in failure modes and edge cases
I’m comfortable shaping logic, not just wiring nodes
I value clean execution histories and low-alert noise
Availability
Open to ongoing, long-term collaboration
Async-first communication works well for me
Happy to start with a small task to validate fit
If this sounds aligned, I’d be glad to discuss your current workflows and where you need the most support.
I specialize in building production-grade n8n workflows for B2B clients. I have already built a few automations for my clients from different industries. I handle API integrations (REST, webhooks, OAuth), error handling, retries, rate limits, etc.
This matches the kind of production n8n work we handle at Hashlogics — real systems with API integrations, rate-limit handling, retries, idempotent design, and workflows that stay stable over time. We spend a lot of time thinking through edge cases, execution data, and failure modes, so the workflows behave predictably even under load.
We’re happy working async and already collaborate with several EU-based teams, so timezone overlap is no issue. Rate-wise, we normally work in the €45–70/hr range depending on depth and responsibility, but we’re flexible and open to the test task.
If this looks aligned, I’d be glad to take a look at your first workflow and outline how we’d structure it for long-term reliability.
I’m an n8n builder focused on production-grade workflows that need to run reliably over time, not experiments or one-off zaps.
I’ve built and maintained workflows that:
Integrate REST APIs, webhooks, and OAuth
Handle pagination, retries, and basic rate-limit constraints
Use idempotent logic to avoid double processing
Trigger alerts only on real failures, not noise
Stay readable and debuggable months later
I’m comfortable inspecting execution data, thinking through failure modes, and shaping workflow logic — not just wiring nodes together. I also use Function nodes with light JS when it makes the workflow clearer or safer.
I’ll design and maintain production-grade n8n workflows that are stable, readable, and safe to run long-term. You’ll get systems that handle real-world edge cases, fail gracefully, and are easy for your team to understand and extend.
Here’s the approach:
• Build API-driven workflows with pagination, retries, and rate limits
• Implement safe deduplication and idempotent logic
• Add smart error handling with meaningful alerts only
• Keep workflows clean, documented, and maintainable
Let’s schedule a call to discuss the details further.
I’m very interested in this role. I’ve been building production-grade automation and AI workflows for European SMEs, including work with Make/Zapier and API-driven systems, and I’m keen to do the same with n8n.
I’m based in Ilmenau, Germany and happy to work async within European time zones.
If it’s helpful, I’d be glad to do your paid test task (2–3 hours) to show how I think about reliability, idempotency and failure handling in workflows.
Best regards,
Sayan
Email: sayanpm17@gmail.com
Phone (DE): +49 176 85636741
A lot of responses here, but something about this post stood out. You mentioned someone who’s built real-life workflows, not just demos, that’s me.
Before moving into automation, I was a full-stack developer, so I’m comfortable with APIs, pagination, concurrency, and building workflows in n8n that actually hold up in production.
You can check out my GitHub here: https://github.com/EmmanuelVictor62. I’ve also attached a screenshot of a recent automation I worked on to give you a sense of my work.
If it sounds like a fit, feel free to reach me at emmanuelvictor.dev@gmail.com. Would love to chat about collaborating.
I might not have shipped as many n8n workflows as others have, but I bring a strong IT background with 17 years of experience, including software engineering.
Recently, I built an n8n workflow static analysis tool FlowLint, which is free and open-source.
I’m a Supabase/API pro based remotely in Europe (speak English/German). I build complex, production-grade workflows - data-heavy + using multiple APIs.
Currently I’m building a search engine for 3,000+ data points using n8n and Supabase, after finishing a social media analysis + scripting tool.
What to expect from me:
complex API integrations
data integrity with strict deduplication logic to handle messy scraped data
handled pagination and rate limits
For work samples, please DM/email me at sarah@viralreelscreator.com. Available for up to 30h/week and can complete the paid test task asap.
This is exactly the kind of work I do best — production-grade n8n workflows that need to be bulletproof, not just demos that look good in screenshots.
Why I’m a strong fit for your requirements:
Real production experience: I’ve built and maintained complex n8n systems including Project Avalanche (multi-step Telegram bot with state management, error recovery, and rate limiting) and Bluume (voice-capture system with API integrations and MCP). These are live systems, not experiments.
I think in edge cases: My background (12 years full-stack AI/web development) means I design for pagination, retries, rate limits, and idempotency from the start. I’ve dealt with the “don’t wake anyone up at 3AM unless it’s real” problem — clean alerting is non-negotiable.
Async-first workflow: I’m based in Vietnam (GMT+7), which gives solid overlap with Europe and I work async by default. Clear documentation, modular design, and maintainable code so handoffs are smooth.
Open to the paid test task: Happy to do a 2-3 hour paid trial to show how I work. You’ll see how I structure workflows, handle failure modes, and document for long-term maintenance.
What I deliver:
Clean, modular n8n workflows (not spaghetti)
Proper error handling and retry logic
Documentation your team can actually use
Fast iteration — I typically deliver in 24-48 hours
Let me know what systems you’re integrating (Stripe/CRM/internal tools) and whether you need more net-new builds or maintenance work. I can confirm fit quickly.
