AWS Cohere Embed v4 Model Error
An error occurred while embedding documents with Bedrock: Malformed request. Please check your parameter/values and try again.
An error occurred while embedding documents with Bedrock: Malformed input request: #: required key [images] not found#: required key [texts] not found#: required key [texts] not found#: required key [texts] not found#: required key [texts] not found#: required key [input_type] not found#: extraneous key [inputText] is not permitted, please reformat your input and try again.
This error only happens when I try to use a Cohere models through AWS, If I’m using a cohere model directly from cohere it works file. If there any fix for this?
