I want to use the node for AWS lambda to execute my task.but i meet a problems.
how should I solve it ?
Welcome to the community.
Just tested it and it’s working just fine for me.
Why is it the function field in red? is it the server running? in which line the body is undefined?
There is no region called cn-northwest-1 according to this
Got it. Well I will suggest you make sure the credentials have attached a policy with access to execute a lambda function.
I confirmed it again.the credentials have attached a policy with access to execute a lambda function.Is there any other plan ?
Thanks for reply. I finally solved this problem, the core problem is the correct endpoint is lambda.cn-northwest-1.amazonaws.com.cn ,but the source code is ${service}.${credentials.region}.amazonaws.com
ahh that is quite weird as it works for me with the current form. I wonder if this applies just for that region.
@jan the lambda endpoint url for cn-northwest-1 and cn-north-1 is endswith amazonaws.com.cn ,Can this compatible support be updated to the next release ?
Added it to my TODO list.
@RicardoE105 I was pleasantly surprised to find that the latest version of N8N already supports custom endpoints. I couldn’t wait to use it, but I got the following error.
Hey @liushengyi about two weeks ago I fixed a bug with this issue here: Fix AWS lambda and SNS problem with signature by krynble · Pull Request #1361 · n8n-io/n8n · GitHub
Should be working fine now. Have you tried it recently? I think it was fixed in version 0.101 if I am not mistaken.
It has been working,Thank you~
