I am using AWS S3 node to upload binary data to a bucket. I am able to upload small text files. But a 10 MB csv file that is read from local as binary and re converted to binary for eventual upload to S3 using AWS S3 node. It gives error:
“message”: “Request body larger than maxBodyLength limit”,
“name”: “Error [ERR_FR_MAX_BODY_LENGTH_EXCEEDED]”,
“stack”: “Error [ERR_FR_MAX_BODY_LENGTH_EXCEEDED]: Request body larger than maxBodyLength limit at RedirectableRequest.write (/home/gowtham/n8n/node_modules/follow-redirects/index.js:102:24) at RedirectableRequest.end (/home/gowtham/n8n/node_modules/follow-redirects/index.js:127:10) at dispatchHttpRequest (/home/gowtham/n8n/node_modules/axios/lib/adapters/http.js:328:11) at new Promise () at httpAdapter (/home/gowtham/n8n/node_modules/axios/lib/adapters/http.js:46:10) at dispatchRequest (/home/gowtham/n8n/node_modules/axios/lib/core/dispatchRequest.js:53:10)”,
“code”: “ERR_FR_MAX_BODY_LENGTH_EXCEEDED”
Hey @Gowthaman_Prabhu, I am sorry to hear you’re having trouble.
I just tried uploading a 20MB file and didn’t have any trouble:
Could you confirm which version of n8n you’re currently on and share a workflow using which the problem can be reproduced?
Hi,
I am using version 0.176.0.
My Workflow:
Simple workflows with just an upload node fails too. I am only able to upload upto 4 MB…
Thanks @Gowthaman_Prabhu. I don’t have that version of n8n running anywhere at the moment I am afraid
I do however believe this problem could have been fixed with version 0.179.0 as this version includes a bugfix for uploading large files: n8n/CHANGELOG.md at master · n8n-io/n8n · GitHub
Could you test this on your side and confirm whether the issue still persists with n8n versions after 0.179.0?
Thank you @MutedJam. It does indeed work with version 0.179.0
P.S. I tired setting maxContent and bodyLengths at AWS S3 node level. Didn’t resolve the problem with older verisons. I see the change logs and figure I should have modified the parent nodeExecuteFunction.ts instead
Glad to hear this works, thx for confirming!
