Hi @Kent1, ENOTFOUND is a system error and is thrown if a hostname isn’t found. Or in other words the DNS lookup has failed.
Assuming you are using a valid hostname this is most likely a local cause, for example an unavailable or overloaded DNS server. If this is just a temporary problem, you could consider enabling the retry option provided by n8n:
