The Basic LLM chain node throws out an error when plugged with Mistral Cloud Model.
NodeOperationError: Cannot read properties of null (reading 'length') at ChatMistralAI.callMethodAsync (/usr/local/lib/node_modules/n8n/node_modules/@n8n/n8n-nodes-langchain/dist/utils/logWrapper.js:34:23) at processTicksAndRejections (node:internal/process/task_queues:95:5) at Proxy.connectionType (/usr/local/lib/node_modules/n8n/node_modules/@n8n/n8n-nodes-langchain/dist/utils/logWrapper.js:156:47) at async Promise.allSettled (index 0) at Proxy._generateUncached (/usr/local/lib/node_modules/n8n/node_modules/@langchain/mistralai/node_modules/@langchain/core/dist/language_models/chat_models.cjs:118:25) at LLMChain._call (/usr/local/lib/node_modules/n8n/node_modules/langchain/dist/chains/llm_chain.cjs:157:37) at LLMChain.invoke (/usr/local/lib/node_modules/n8n/node_modules/langchain/dist/chains/base.cjs:58:28) at createSimpleLLMChain (/usr/local/lib/node_modules/n8n/node_modules/@n8n/n8n-nodes-langchain/dist/nodes/chains/ChainLLM/ChainLlm.node.js:92:23) at getChain (/usr/local/lib/node_modules/n8n/node_modules/@n8n/n8n-nodes-langchain/dist/nodes/chains/ChainLLM/ChainLlm.node.js:101:16) at Object.execute (/usr/local/lib/node_modules/n8n/node_modules/@n8n/n8n-nodes-langchain/dist/nodes/chains/ChainLLM/ChainLlm.node.js:416:31)
"prompt": "Accueille ton Capitaine à bord, puis annonce-lui les conditions de navigation de la soirée :\nCoucher de soleil : 21h04 ;\nMarée basse à 19h49 à Port-Navalo ;\nMarée haute à 02h45 à Port-Navalo ;\nVent actuel : 15 nœuds, direction nord-ouest ;\nLe vent va baisser jusqu'à atteindre 10 nœuds à 22 heures."
- **n8n version:**1.36.4
- **Database:**SQLite
- **n8n EXECUTIONS_PROCESS setting (default: own, main):**v1
- **Running n8n via (Docker, npm, n8n cloud, desktop app):**Docker
- **Operating system:**Ubuntu 22.04.3 LTS (GNU/Linux 5.15.0-94-generic x86_64)
