Hi
I am building a title generator but when I use Basic LLM Chain and corollate with ai chat bot and item list output parser my output is like this
on the other hand schema page shows one item like this :
My workflow look like this
Because this complication later on my workflow couse code node can not seperate these items ? I need these two item seperated and data can be seperated. On youtube there is this guy gets this out put I figure I need to get this type output
Any idea?
can you provide me youtube link, i think i can help
Here is my workflow, I think because the type of response of GPT and Gemini.
Feel free to ask.
Ozcorp
May 10, 2025, 12:31pm
5
Can you share your output ? Do I need to use gemini to get same output like in the video?
You select all of my workflow and Ctrl + A then Ctrl + C
and paste it to your workflow by Ctrl + V
If you have Open AI key, you don’t need to do anything
But if you are using Gemini, you can do it like my workflow.
Ozcorp
May 10, 2025, 1:57pm
10
Continuing the discussion from Basic LLM Output Costumize :
it worked. Thank you but for my project I have another problem that I need to solve asap. If you help me out it would be great.
I have 2 item as input I want to get datas from these items but no matter what I do I only got 1 item’s data here is my input whole data
In my referance video it looks like this
Any idea?
let open another post bro, i will help you but you have to give me Solutiom Check for the old problem
great, tell me which timeline in the video.
Ozcorp
May 10, 2025, 6:05pm
13
Thank you bro.
The problem I am talking about is in the video. Min : 28:40
If you want I can open a new post
Great to hear that from you Ozcorp
Let open a new post, and before you do that, can you give me a Love and set Solution Checker for me.
I hope we can keep in touch.
system
Closed
May 17, 2025, 6:10pm
15
