Best front end for N8n building style
Hi guys,
I’ve been building with n8n for over 2 years now and am thankful because n8n has really given me the programming confidence to take on projects and even start a small side business.
My full time job is a copier salesman so I’m not technically trained or into coding and some of my projects I’ve built for clients have required a front end.
Considering my love for n8n, I wanted to find a front end that followed the same low code principles with coding options if necessary.
I personally don’t like using vibe coding in my projects for clients because debugging or customizing can become impossible with my lack of coding knowledge.
The closest thing I found to the n8n building style for front end is WeWeb. It’s no code but you can put JavaScript snippets into certain sections if you need something more custom. It also allows you to export your project into raw code which reminds me of the “source-available” nature of n8n.
plus the pricing is very reasonable.
I’ve worked with Softr before and find it a close second but the customization is less and the cost is higher. I’d consider Softr the Zapier of the front end world while WeWeb is the n8n
hope this helps someone as I was looking for a long time for a more customizable front end when the n8n form node wasn’t enough and now almost always go to we web.
curious to hear what you guys are using or think about my insight
-Chrevor
