Hi everyone,
I’m building an n8n workflow for a skincare Product Information Management (PIM) pipeline. The goal is: given one product name (optionally brand), the workflow should search the web, pull data from high-quality sources, validate/compare, and output a strict JSON object with a fixed schema.
What I’m trying to achieve (scope)
Input:
product_name (string) e.g. “Anua Heartleaf Pore Control Cleansing Oil Mild”
optional brand_name
Output:
- A single JSON object (must be valid JSON.parse) with a fixed structure (identity, variant, formula INCI list, claims, usage, warnings, sources), using null for unknowns, and strict types (booleans must be true/false/null, URLs must be raw URLs, arrays must be arrays).
Critical constraints / pain points
Source priority & validation
Prefer official brand site / official regional site as primary truth
Then INCI databases (INCI Decoder, Skinsort, Incibeauty, CosDNA, etc.)
Retailers only as confirmation if they match official
Must resolve variant ambiguity (e.g., “Mild” vs “Original”) by matching product title + INCI list + official URL. If conflict: set official_url = null and explain in notes.
Web search + page reading
I can use SerpAPI (or other search tool) to find candidate URLs
For page text extraction I’m considering:
n8n “Extract Text” node (if it can extract from HTML reliably)
Jina Reader (fetch via https://r.jina.ai/https://…) for clean readable text
Unsure which is more reliable for product pages and INCI sections, and how many URLs to fetch (top 3? top 5?).
Strict JSON output
I want the model to always output strict JSON without markdown links and without type mistakes (e.g. booleans turning into strings/URLs).
I tried manual HTTP calls to Gemini generateContent, but formatting / expression issues made it error-prone in n8n.
I’m considering using AI Agent + Structured Output Parser to enforce schema.
Current approach I’m considering
Chat/Webhook trigger → normalize inputs
Search tool (SerpAPI) to get candidate links (official + databases)
Fetch and extract text for each URL (Jina Reader or Extract Text)
Provide the extracted text to an LLM (Gemini/OpenAI) with strict instructions + schema
Structured Output Parser to enforce final JSON
Optional: a “repair JSON” step if parsing fails
What I’m asking the community
What’s the best-practice workflow pattern in n8n for this “grounded extraction + validation + strict JSON” use case?
Should I use AI Agent or keep it as a deterministic chain of nodes (Search → Fetch → Extract → LLM → Parser)?
For reading pages: Extract Text vs Jina Reader — which tends to be more reliable on real ecommerce/brand pages?
Any tips to reduce hallucinations and improve consistency (e.g., always include citations per field, require sources.what_it_supported, etc.)?
If you’ve built something similar, what node stack + settings worked best?
If helpful I can share my target JSON schema and a sample output.
