Hello !
I’m working on a use case where I want to send daily sales reports (CSV format) to an LLM agent to generate summary and insights automatically.
Right now I’m considering two options:
- Convert the CSV (from Google Sheets) into a single JSON object and send it directly to the LLM.
- Upload the CSV into a vector store and let the LLM retrieve and analyze it from there.
My concern is that vector-based chunking might miss overall patterns or insights, while sending a large JSON might hit token limits. (I tried letting the LLM calculate the total sales, but it got the numbers wrong.
My goal is to get accurate, high-level analysis from these daily reports with minimal manual prep.
Would love to hear how others have handled similar cases. Any suggestions or alternatives are appreciated.
Hey @Pichayut_Prasertwit,
Why don’t you do the math yourself, send only the results to the LLM.
Calculate totals/averages in your preprocessing script
Send LLM a summary object with the numbers + a few sample rows
LLM writes the narrative, doesn’t calculate anything
This fixes the accuracy problem and avoids token limit
Ex
"date": "2025-01-15",
"total_sales": 45230.50,
"vs_yesterday": "+12.3%",
"top_products": [...],
"key_metrics": {...},
"sample_data": [10-20 most relevant rows]
I prefer the first options because I do like to calculate it first before I’m talking to AI about my document. Basically, I would like to count average, summary, and total about the sales, and also adding top 5 products if it’s possible.
If you’re using AI Agent in the n8n workflow, I would prefer to directly call the google sheet without converting it and talk with AI to do thing with my sheet
