Best way to troubleshoot Slack error response: "invalid_arguments"
In a scheduled workflow that ends on sending out Slack DMs I (seemingly) randomly get the error Slack error response: “invalid_arguments”.
While the error is quite straight forward I am struggling with troubleshooting this. Would be great to be able to see the actual request headers/body that n8n sends to the Slack API but presume that’s not possible?
Any suggestions on how to go about troubleshooting this?
n8n cloud on version 1.33.1
Hi @jaand
Thanks for posting here and welcome to the community! :cake:
Would you be able to share your workflow here and/or paste some screenshots?
You can simply share your workflow here by pasting their JSON content (after you download the workflow from you workspace) in between two block quotes (```).
I’d like to understand what it is you’re trying to do exactly.
Thanks! :raised_hands:
Sure, can’t share workflow since it has some sensitive parts in code blocks.
But here are a couple of screenshots.
Was hoping to get some general information on how to troubleshoot this.
Of the 43 input items I don’t know which one i get the error back on nor can I see what is sent to the Slack API for the request that gives back the “invalid_arguments” response.
Would be good to know if there are ways to get that information
