Binary Data not flow through to the subworkflow
It would be much appreciated, if someone could help with this problem.
First, there was a thread talking about the same issue, but it was closed and advised that the bug has been fixed in 1.74.3
Basically, the problem is the binary data didn’t flow through to the subworkflow
Parent:
Sub workflow:
Screenshot
  • n8n version: 1.76.1
Welcome to the community @Alan_Cui !
Tip for sharing information
Pasting your n8n workflow
<your workflow>
You still seem to be using the older version of the nodes. Plese, upgrade to the latest 1.76.3 and replace the nodes with their new versions from the Nodes panel. You can see the node version when navigating to the Settings tab. For example,
