napped
October 16, 2025, 3:01pm
1
Input binary data is not accessible in Python (Beta) node.
Instead of base64 data in the data property, there is a following text: filesystem-v2
“binary_base64”:
“filesystem-v2”
n8n version: 1.115.3
Database (default: SQLite): n8n Cloud
n8n EXECUTIONS_PROCESS setting (default: own, main): n8n Cloud
Running n8n via (Docker, npm, n8n cloud, desktop app): n8n Cloud
Operating system: n8n Cloud
napped
October 23, 2025, 9:22am
2
Tested on n8n@1.116.2 cloud and still the same problem. How to let the devs know about this issue?
moosa
October 23, 2025, 11:58am
3
hello @napped
If I understand your question correctly you want to extract as base 64.
napped
October 23, 2025, 1:27pm
4
@moosa thank you
moving the binary payload to json worked and helped me move forward, however this is just workaround.
The original issue that Python node cannot access binary data directly (without moving them to json first) is not solved, so I’m leaving this open for devs to know
