Binary to JSON problem
I try to convert some binary data in a json to readable data encoding in utf-8 in a new field.
“meta”: {
“instanceId”: “3c306c4580d5053e06c89fde170880165a84bf6f23a8f85375e30a1b08e929f7”
“nodes”: [
“parameters”: {
“setAllData”: false,
“sourceKey”: “={{ $json.xml }}”,
“options”: {
“encoding”: “utf8”,
“keepSource”: true
“id”: “e93db011-a789-4fbb-8106-9e0564f3088a”,
“name”: “Get junit file”,
“type”: “n8n-nodes-base.moveBinaryData”,
“typeVersion”: 1,
“position”: [
420,
820
“alwaysOutputData”: true
“connections”: {}
I expect to have some data in the output of my node but I don’t understand why there is nothing.
Thank you for your help.
Hi @Jerome_Blache I’ve created this topic about this few months ago.
Maybe can help you?
Hi @Jerome_Blache, welcome to the community!
I am sorry you’re having trouble. In addition to what @Gabriele_Bracciali has shared it’d be great if you could share some example data you’re working with. If it’s a base64-encoded file you currently have (and you don’t want to write custom code) you could consider simply using two Move Binary Data nodes to convert this into a human readable string:
The first one would create a binary file based on what appears to be base64 data, the second one would read it as a string.
Thank you for your answer.
Thank you, it’s working now. I was able to retrieve my XML data using this method. I wasn’t aware that my file was base64-encoded.
This was my first time posting a question in this community, and I’m pleasantly surprised by how quickly people responded. n8n is a fantastic tool, and I hope you’ll continue to provide support to users like me in the future.
