Bug: Auth0 predefined credentials do not work
Exact same issue as reported in BUG: Predefined Credential Type: Auth0 Management API
I’m using a Cloud tenant of n8n, I’ve created a dev tenant in Auth0 which I’ve made a Machine to Machine application for, copied from their interface the tenant, client ID and secret ID so the creds are definitely good. Assigned the ‘read users’ scope as that’s all I need to do with this workflow.
The credentials do not work, I get a 403 error.
It’s not in a workflow, I’m just trying to save the credentials at this point.
Not relevant
  • n8n version: [email protected]
