[Bug] Error with system message when using Google AI model in AI Agent node
Hi n8n team,
I’m encountering an issue when using Google AI models (such as PaLM or Gemini) in the AI Agent node.
When I include a system message in the chat memory, I get the following error from the model:
[ERROR: System message should be the first one]
:white_check_mark: Expected:
The system message should be accepted as long as it’s configured correctly in the chat memory.
:cross_mark: What happens:
Even when the system message is set properly, the model returns this error. It seems like the message is not being placed as the first item in the message array before being sent to the Google API.
:magnifying_glass_tilted_right: Notes:
  • This issue only affects Google AI models.
  • According to Google’s documentation, the system message must be the first message in the array.
  • When using OpenAI models, the same configuration works fine and no error is thrown.
  • It appears that a user message is being inserted before the system message, which causes the error.
Thanks in advance for your attention!
Let me know if you need more details or logs.
Hi @Midas_start,
Apparently, Google can’t re-order the messages themselves :sweat_smile:
I can see how this is not expected from your point of view. I’ll add the issue to our issue tracker, but in the mean time: please think about how to avoid this situation yourself. You could, for example, separate the two messages, and make sure you only add the system-message once.
Thanks for the report!
