Built a fully controllable AI blog writing system in n8n. Here’s a breakdown of how it works. [Template provided!]
Hey everyone,
I work a lot with content writers and blogs in general. And I was given a case that I considered a challenge:
The big workflow
One marketing & content agency deals with dozens of websites and their blogs.
They hire a team of SEO writers from India to write 10K+ words a month, get low-quality slop, and hire full-time editors to handle it.
The result?
  • $1K on freelance costs, another $10K on full-time editors every month.
  • Overlong production pipelines.
  • Inconsistent quality.
  • Brand and product misalignment.
  • Missed deadlines.
  • Clients lost because of it.
So, I built a system entirely on n8n that acts as a “glass box” content factory. It writes intent-based articles in under 10 minutes, and takes less than $1.5 in API calls. I’m sharing the JSON and setup guide below.
The core idea is using Google Drive file movements as triggers, creating manual approval gates between workflows.
Here’s a breakdown.
Workflow 1: Keyword Research & Curation
This workflow automates the most tedious part of SEO: finding and validating keywords.
Input:
You manually trigger it with a topic (e.g “AI tools”) and an intent (e.g “Informational article on how to choose AI tools”).
Actions:
  • Pulls keyword suggestions from Google Autocomplete & a free API from RapidAPI.
  • Autocomplete generates 10-15 keywords; the free API may give a raw list with hundreds of terms.
  • An LLM analyzes the raw list and filters it down to the 10-15 most semantically relevant keywords for your specific topic.
  • Saves the curated list to a Google Sheet in a [PRE_APPROVE] folder.
Human Checkpoint: The system pauses here. You review the sheet, make any edits, and approve it by moving the file to the next folder.
The final Google Sheet with columns for keywords, topics, intent, etc.
Workflow 2: Brief Generation
This is where the real “smarts” of the system come in. It creates a deeply researched brief based on what’s already ranking.
Trigger: Starts automatically when you move the approved keyword sheet.
Actions:
  • Browses the Google AI Overview for user topics, pains and solutions. We use SerpAPI Community node for that.
  • Scrapes 5 most relevant references from the Overview. We use a Headless Browser community node called n8n-nodes-browser for that.
  • An LLM deconstructs their content, extracting article headings, key statistics, discussed topics, and expert quotes.
  • Analyzes all these insights, then creates a new, unique, and SEO-driven article brief in a Google Doc: Article size, Meta title & Description, Keywords, Headings
For example:
  • If it’s the informational intent → Problem-focused outline with expert insights, tips, and examples.
  • If it’s the comparative intent → The outline includes pros, cons, and usage examples of different products.
  • The highly detailed prompt for structure generator also includes guidelines for how-to’s, listicles, reviews, buyer’s guides, checklists, and case studies.
Human Checkpoint: The system pauses again, waiting for you to review and approve the brief. You can add brand guidelines, product notes, backlinks or internal links, as well as anchors here. Or, make your own brief - the system accepts it too, just take into account that it should follow a very specific layout.
r/n8n -  The generated Google Doc brief, showing the detailed structure, H1, meta description, and topics|750xauto
Workflow 3: Final Article Writing & Export
This is the assembly line. It takes your human-approved brief and turns it into a publish-ready article.
Trigger: Starts automatically when you move the approved brief document.
Actions:
  • A research LLM finds 3 new relevant source articles (like factual articles from experts, research reports or case studies) to provide fresh context.
  • The main writing agent uses these three sources, a giant prompt, and our detailed brief and the new sources to write the full article in clean HTML.
  • Creates a final Google Doc with formatted headings, lists, paragraphs, and tables from the HTML and saves it to the Final Articles folder. We use a specific HTTP request method for that:
const boundary = ‘-------314159265358979323846’;
const meta = {
mimeType: “application/vnd.google-apps.document”
const htmlContent = $json.output.article_html;
return (
--${boundary}\r\n +
Content-Type: application/json; charset=UTF-8\r\n\r\n +
JSON.stringify(meta) + ‘\r\n’ +
--${boundary}\r\n +
Content-Type: text/html\r\n\r\n +
htmlContent + ‘\r\n’ +
--${boundary}--
The results:
  • SEO Teams get a way for more traffic and automated backlinking with EEAT-compliant, SEO-optimized articles.
  • Content Team Leads and editors get a predictable & scalable draft pipeline without the freelancer chaos.
  • Marketing Leads get on-brand, product-aligned content ready for promotion.
I’ve documented the entire system in my Notion guide. You can clone and use it yourself. Or, ask me for a full custom build if you don’t have time for setting it up.
See the full demo, guide, article samples, prompts, and workflow JSON here: https://www.notion.so/Fully-Controllable-AI-Blog-Writing-System-254b9929cddc8061b5eac304e1b8b2bc
(unfortunately, I couldn’t paste the JSON as a template because of some HTML-related file formatting restrictions)
Happy to answer any questions about the build!
That’s amazing! I’d love to see a breakdown of your workflow. I’ve been working on a similar project and have incorporated a https://cleverhumanizer.ai/ humanize AI text tool into my n8n pipeline. Overall, it has been very successful; it greatly enhances the naturalness of AI output, integrates seamlessly via API, and processes data fairly quickly. produces phrases that occasionally require manual adjustments, and the documentation could be more thorough, but the quality improvement is significant. improves automated content workflows without a doubt. Which humanization strategy are you employing?
