Hey n8n Community,
Bit of background first. I originally built this extraction setup to serve my own automation projects, mostly document classification and pulling structured data out of PDFs and invoices. It worked so well for me internally that I decided to open it up so anyone can use it.
The new use case
In my last project I needed product photos described so I could feed that into content generation, and I almost reached for a separate vision model. Turns out the Extractor handles images really well, which is the moment it clicked that this is more than a classic data-extraction tool.
Instead of pointing a pipeline at a document, you point it at the image and define the fields as questions about what’s visible: dominant colour, visible features, material, the type of shot. It comes back as structured fields, exactly like a document extraction, so the result drops straight into the rest of the workflow with no paragraph to parse and clean up.
The workflow
I recorded a short video walking through it, attached to this post. You can also see the actual workflow I built around this case here: n8n-workflows/easybits-product-content-creation-workflow at e3103344d9b3358402dc38a3a862d510bb4e7c5e · felix-sattler-easybits/n8n-workflows · GitHub
n8n Cloud: it’s a verified node, just search
easybits Extractorin the node panel. Nothing to install. -
Self-hosted: Settings → Community Nodes → Install →
@easybits/n8n-nodes-extractor.
Then create a pipeline, define your fields, and point it at an image instead of a doc. There’s a free plan with 50 API requests a month included, which is plenty to test the image use case end to end.
Anyone else using extraction tools for image understanding rather than a dedicated vision model? Curious what you’re pointing them at.
Best,
Felix
