Is there now a working workflow that syncronizes the Nextcloud calendar?
Hi folks, sorry for reviving an old thread but I just remembered this was a somewhat popular request. Just wanted to let you know that Iāve published an early version of a CalDAV community node a while back:
The repo says itās bad idea to use it right now, but thatās because it is very limited and doesnāt have many operations. If your goal is to simply fetch events within a given time window from a calendar, this will probably get the job done:
Iāve used this node to send custom notifications to a smart clock about certain events based on the CalDAV calendar provided by my email provider Posteo for a couple of months now (using it on n8n 0.236.3 at the moment).
It should hopefully work with other calendars too, but I havenāt tested Nextcloud yet. Feel free to fork this as needed if you need more features or just let me know. It might take a bit before I can revisit this one though ![]()
Thanks for this share.
Iām pretty new using n8n, how can I add a credential to connect to a specific caldav ?
Thanks !
Hi @nmatton, to create a new credential on this custom node (or any other node) you can open the dropdown list under āCredentialā, then select the āCreate New Credentialā option. Iāve highlighted this below:
Hope this helps!
hey @MutedJam,
Are you able to send and retrieve email through n8n using Posteo as your email client? Iām trying to find an alternative to Gmail to interact with my emailsā¦
Thanks a lot!
Hi @headset907, I am using Posteo for my personal email but am not currently automating anything in there.
Instead, I am using a Fastmail account for my automation needs which supports JMAP (a protocol that plays well with the HTTP Request node):
As for a regular (non-trigger) node supporting Posteo, I think umanamenteās community IMAP node might be an option. I havenāt used it myself, but the featureset looks pretty good to me:
Nice @MutedJam ! Thanks for sharing.
So youāre using this Fastmail setup with JMAP for your business automation because it is easier right?
Mainly because I can use my own domain with Fastmail, which wasnāt an option with Posteo. I still love Posteo though ![]()
But yeah, Fastmail has also been working hard on the new JMAP protocol (the idea is to provide a single modern alternative to IMAP, CalDAV and CardDAV), and thatās something I like a lot because it makes automation a lot easier.
Thanks for your insights @MutedJam , Iām gonna look into it ![]()
@MutedJam last thing !
Have you come across this service?
It looks very promising as well (open source, Unlimited custom domains and API included), Iād be curious to know what you think of it!
cheers
Looks pretty sweet indeed, if it fits your use case it definitely seems worth a shot ![]()
Any update on the CALDAV topic? Would love to maintain my Apple calendar (which is caldav as far as I know).
+1 CalDav (Create, delete, pull)
I have a Mailcow server with Sogo (Webdav, CalDav, CardDav) and would also need a node
+1 for a CardDAV/CalDAV node.
I love n8n because I can have POWERFUL automations fully under my control and on my own hardware.
I want to do the same thing with my contacts (self hosted, not stored on someone elseās hardware), and Iād love to manage my contacts system with n8n.
Right now, thereās no viable path to that.
Iām a Fastmail user so +1 to a WebDav/CardDav/CalDav/JMAP node!
+1 from me as well for CalDAV and CardDAV.
Currently I use n8n-nodes-imap which works quite well so far for me for sending/receiving email. Though it does not have a trigger, I use the built-in IMAP trigger and then send the trigger to this node to get the emails.
+1 from me
+1 from me. Standard protocols like CalDav and CardDav should be supported.
+1 at least add REPORT, and other methods to HTTP Request it should be very easy
Whatās the situation currently on CalDAV/CardDAV? I am motivated to find a solution for this.
A problem I can 95% certainly solve is translating the dataset to and from JSON as @MPO mentioned. Will that help anyone here solve our CalDAV (and Nextcloud) holdup?
Ep
