Can n8n connect with Business Intelligence Tool Like Power BI Tableau Qliksense Looker Studio any of them
I dont find any Business Intelligence tool in the workflow . It would be a great help if we can do this .
Thanks
What are you exactly looking for?
A BI platform is usually the end of the line with regards to data.
Do you want to prepare data for it or extract data from it? Or something else of course.
Actually I am looking to connect to the products that I have made in Power BI or Looker studio and gain best insights like a newsletter
Not sure what you made in Power Bi or Looker.
I am only familiar with Qlik and that it is pretty complicated getting stuff out of it, as it is all hypercubes and such. Not sure how that would be with something like Power BI.
Easiest would probably be to connect to the same data source as you use for Power Bi / Looker and use that for whatever you want to create.
