Can N8n connects to FTPS with Implicit mode 990 and can it offers static IP
Can N8n connects to FTPS with Implicit mode 990 and can it offers static IP.
I have a use case to build which i require to connect to FTPS with 990 Impilcit mode and client should restrict for IP address. even if that is a pool
N8n Cloud version to be able to connect to FTPS client server and then upload xml files and invoices into the specific path folder
Hi @sureshpatti,
We don’t fully support FTPS, I would recommend swapping to SFTP which generally works better for file transfers it is secure and has built in integrity checking.
