Can not active flow cause of Telegram Trigger
Hi everyone,
I just would like to do some tutorials with telegram. but I was stucked right from beginning when I set telegram trigger. I could not activate flow neither execute this node
I have no idea for this issue. Please help me!
The token was fine but the flow could not run…
Hi @Nguyen_Duc_Hoan, welcome to the community!
n8n’s trigger nodes use webhooks under the hood and it appears Telegram rejects non-https URLs.
So you’d want to make sure your n8n instance is available under a public https URL here. If you’re using a reverse proxy to handle SSL/TLS termination you might need to set the WEBHOOK_URL environment variable to share the correct URL with n8n.
