I want to convert decimal number to hex through function node
example : 9181 to 23DD
Can someone help
Can someone help
Hey @Priya_Kumar,
I had to do a bunch of this stuff at my old job for converting card numbers between different formats, In theory you don’t need a function you can just use yourNumber.toString(16) in an expression but to be complete the workflow below shows it in a function.
thanksa lot jon. solved
