Can’t receive my Unique ID for Level 2 certification
Hi there,
I’m trying to register for the Level 2 certification, but I haven’t received the email with my Unique ID. Because of that, I can’t start the practical exercises or take the final exam.
I already checked my spam folder and tried registering again, but still haven’t received anything.
Could someone please help me with this issue?
Thanks in advance!
— Alex Diaz
Hey Alex, my uniqueID was the same for Level 1 and 2. You could try using your Level 1 uniqueID.
Although you’ll still need to get the URL’s and Header Auth name and value.
Yes, I noticed that it’s the same Unique ID, and I also think the Discord link might be different.
I completed the Level 2 exam, and since it uses the same Unique ID, I was able to take it — but I haven’t received my results yet.
I’m guessing there might be a system issue.
Thank you very much for your support!
Thats awesome you completed it! You can check the status here to see if there is anything left to do. I know the last step is notifying the team in the discord so you will need that link. You’ll also need the dataset url and the Header Auth name/values. Did you ever get the email?
verify link:
discord link:
https://internal.users.n8n.cloud/webhook/discord-level2
Hi there,
I wanted to let you know that I contacted n8n Support by email, and they helped me by sending the information I needed for Level 2.
Thank you very much for your help and support on my post, and my apologies for the delay in replying.
Best regards,
Alex
