I’m trying to connect the help scout node, but when I try to connect my account and connect with my help scout account, I get the following screen. Not sure if this has to do with Help Scout updating their api or if something is wrong on my end.
I need the “Redirection URL” to create my custom app in Help Scout.
ahh yes, you can find the redirect url in the credentials. It’s called “Auth Callback URL”.
Thanks! Although, I get an error when I try to connect my Help Scout account to the n8n node.
Any idea what I can do?
@richardjlo please try again. It should work now.
Worked! Now, where do I get the OAuth Callback URL?
I don’t see the dropdown
You do not need it if you are in cloud.
Got it! Didn’t realize that. Thanks!
