Hello. I’m trying to install n8n using this Docker Compose guide: Docker Compose | n8n Docs
When I first got to Step 8 and used sudo docker compose up -d
I got an error that said:
Error response from daemon: failed to populate volume: error evaluating symlinks from mount source "/var/lib/docker/volumes/n8n_data/_data": lstat /var/lib/docker/volumes/n8n_data: no such file or directory
I checked the /var/lib/docker/volumes and in fact, there was no n8n_data volume, even though I was sure I created it on Step 7 with sudo docker volume create n8n_data
. The traefik_data volume was created as expected.
I tried creating a n8n_data folder directly inside the docker volumes and ran the composer again, but now it said:
Error response from daemon: failed to populate volume: error evaluating symlinks from mount source "/var/lib/docker/volumes/n8n_data/_data": lstat /var/lib/docker/volumes/n8n_data/_data: no such file or directory
I tried creating a _data file inside the n8n_data, but I didn’t know what to put in it… I tried searching for it but found nothing.
I did use the - /local-files:/files
line on the docker-compose.yml, if that makes a difference. I removed it and tried running again, but nothing changed.
- n8n version:
- Database (default: SQLite):
- Operating system: Ubuntu 20.04
