So I’m running an AI chatbot from my website to a webhook that goes to an OpenAI message a model. First off, I have {{$json[“message”]}} inside the OpenAI node to ask the model the question from the chatbot, which doesnt seem to work.
Second, no matter how hard I try (Code Node, Set Node, Filter Node) I cannot seem to extract ONLY the text response from OpenAI’s response. Either I get all the raw code, or it comes out as undefined or empty. Here are some screenshots showing the workflow working, but not as intended. Here is the code I used for the Code Node and here is the Open AI output:
| output | |
| 0 | id:msg_0cc9551e5829c33e006902b9966f7081909d327d17b7d4e07f |
and here is the code I was using for java: let assistantText = “”;
// Return the assistant text as JSON
return [
json: {
responseText: assistantText
Where am I going wrong?
