Change column values for monday.com
Hello community, I am rather new to n8n and an absolute beginner in node (I have no clue what I am doing really, its just testing until something eventually works).
I have seen this question on a similar topic before but I need to ask again:
I want to change a column value, more specifically a status, in monday.com
The issue is the value in n8n. It needs to be a node and I have no idea how to get it right.
Most of the time n8n says I need to have a proper json in my expression (yea no clue how to achieve that) but I dont really get how it works.
monday.com actually says to use this:
JSON.stringify({ "label": "Done" });
in my json.
well, that doesnt help me at all.
I think the easiest way to help me would to just send me the right json/node to put in the value. I am also almost done with my nerves with this.
@fwkenzo welcome to the community.
What is the type of the column you want to update/set?
If the value is type text then perhaps you can find the answer there
Thank you for your help!
I found a solution.
This was annoying as hell to figure out, so leaving the answer here for any future voyagers :sunglasses:
Status is represented by a number, e.g. 0 Working on it 1 Stuck 2 Done.
But you have to pass this as {index: <number} for it to register.
Here is a working example:
Thanks man!
