Hi,
I’m trying to use self-hosting n8n in windows.
I successfully build and run source code, but i have question.
While workflow is running, when i click “All Executions” tab, my workflow is shown in list.(status is running)
When i click my running workflow in all executions, I can’t check which node is running.(It just show to me that workflow is running)
If i use cloud version of n8n, can I check current running node in “All Executions” tab?
Or is this a feature that is not supported?
*There is no running workflow in the snapshot below. Failed to capture while running.
You can only check the current progress if you are running the workflow manually in the editor other than that you can only see what is happening once the workflow has finished. It may be worth a feature request if this would be something that you are interested in assuming there isn’t one already.
