Hi Everyone! ![]()
Jesse from Lusha here to show you how to handle messy lead intake before it hits HubSpot using n8n. Leads coming from Google Sheets and Telegram are normalized with AI, checked against existing records using hard and fuzzy matching, enriched with Lusha only when needed, and then synced as clean, trusted records. The result is fewer duplicates, lower enrichment costs, and a CRM people actually trust. You can also find the full workflow tutorial in Lusha’s campus and other n8n workflows here. Enjoy!
How to set it up
01 Use the n8n template
Start from the “Sync and enrich HubSpot leads from Google Sheets and Telegram with Gemini and Lusha” template. It handles intake → normalization → matching → enrichment → CRM sync in one flow.
02 Connect all credentials
Authenticate in n8n:
HubSpot
Lusha API key
Google Gemini
Google Sheets
Telegram bot
03 Configure your Google Sheet
Input your Spreadsheet ID in both:
The Trigger node (listens for new rows)
The Acknowledge node (updates status after processing)
04 Set up Telegram trigger
Configure the Telegram node to listen for messages in your designated lead channel or bot. Unstructured text messages will be parsed by Gemini.
05 Adjust matching sensitivity
In the Switch Logic node, set your fuzzy matching algorithm threshold:
Default: 80% (recommended starting point)
Higher (85–90%): Stricter matching, fewer false positives
Lower (70–75%): Looser matching, catches more variants
This two-tier matching (hard + fuzzy) prevents duplicates and saves Lusha credits by avoiding unnecessary API calls.
06 Configure enrichment triggers
The workflow automatically calls Lusha’s Person and Company APIs only when key fields are missing—like email, role, or firmographic data.
This targeted approach keeps costs efficient at scale. You’re not enriching everything, every time, just filling gaps.
07 Test with both input types
Try sample inputs:
Google Sheets: Add a row with name, company, email
Telegram: Send “John Smith at Acme Corp, worth reaching out”
Confirm:
Gemini normalizes Telegram text correctly
Matching catches existing HubSpot contacts
Enrichment runs only when needed
HubSpot updates appear (create or update)
Google Sheet status updates
Telegram confirmation message sent
What you get
A flexible intake engine that accepts leads from multiple sources (Sheets, Telegram, or any webhook), normalizes messy inputs into a standard structure, intelligently matches against existing HubSpot records to prevent duplicates, enriches conditionally (only what’s missing), and closes the loop with status updates and notifications.
What did you think? Happy to answer any comments or questions in the comments below!
