CLI - workflow does not exist
Hi, i´m often running workflows via cli. Since upgrading to Postgres from sqlite I get the message:
n8n execute --id doPQFFohnjYueIos
The workflow with the id “doPQFFohnjYueIos” does not exist.
  • **n8n version:1.17.1
  • **Database (default: SQLite):Ppostgres
  • **Running n8n via (Docker, npm, n8n cloud, desktop app):npm
  • **Operating system:macOs
You have to make sure that the configuration of both is identical. I assume the problem is that one n8n runs now with Postgres and the one you start via CLI, probably still with SQLite.
Hi,
thx, not sure. This was the only installation and sqlite completely removed.
Ended up installing it again.
Thx!
