Coda n8n connection
Hello, I’m trying to connect with Coda (using n8n’s pack) but it does not work)
We’re using the self hosted version on windows
Couldn’t get updates from n8n for Coda as of 5 mins ago. Try again in a few minutes or check your settings.
Failed to fetch data from n8n for Coda
Reason: unable to verify the first certificate
We have a godaddy certificate and it’s valid (in fact, I can access the domain and use n8n from another laptop, also in the api playground I have no issues, i can retrieve data with 200 response)
We’re also using nginx as reverse proxy
I don’t know what I’m doing wrong
  • n8n version: Version 1.36.2
  • **Running n8n via (Docker, npm, n8n cloud, desktop app):**npm
  • Operating system: windows 11
Hi @o_morales
Thanks for posting here and welcome to the community :partying_face:
It would be really helpful if you could share your workflow here, so we can try to reproduce the error you are getting.
You can simply share workflows here by pasting their JSON content (after you download the workflow from you workspace) in between two block quotes (```).
Also if you have any screenshots of what you are seeing, that would be good!
Thanks :slight_smile:
Thanks!
In n8n I’m just trying to execute the curl that the n8n Public API gave me (for testing)
Here is my code:
and I noticed that if I ignore SSL it works, otherwise it shows the following error:
When I’m using the API it works
And in Coda I put this
and get the same error
This is my nginx.conf
worker_processes auto;
error_log logs/error.log;
events {
worker_connections 1024;
http {
server {
listen 82;
server_name n1nl.gcien.com www.n1nl.gcien.com;
return 301 https://$host$request_uri;
server {
    listen 443 ssl;
    ssl_certificate /path/to/credentials/;
    ssl_certificate_key /path/to/credentials/;
    ssl_protocols TLSv1.2 TLSv1.3;
    ssl_ciphers HIGH:!aNULL:!MD5;
    ssl_session_cache shared:SSL:10m;
    ssl_session_timeout 10m;
    ssl_stapling on;
    ssl_stapling_verify on;
    ssl_trusted_certificate /path/to/credentials/;
    location / {
        proxy_pass http://localhost:5678/;
        proxy_set_header Host $host;
        proxy_set_header X-Real-IP $remote_addr;
        proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
        proxy_set_header X-Forwarded-Proto $scheme;
        proxy_next_upstream error timeout invalid_header http_500 http_502 http_503 http_504;
        proxy_redirect off;
        error_page 500 502 503 504 /error.html;
        location = /error.html {
            root /path/to/your/error/pages;
            internal;
    access_log logs/access.log;
And the certificate
Thanks again for your time :smiley:
