Code node in "Execute Once" mode only outputs first item from array
Hello,
I am running a self-hosted n8n instance, version 1.107.3.
I have a Code node set to Execute Once: ON. It receives a list of 50 items. The code inside is return items.slice(0, 20);.
I expect the node to output 20 items, but it is only outputting the first item from the sliced list. Can you please help me diagnose why it is not returning the full array of 20 items?
Hey @Matthew_Broadbent hope all is good. Welcome to the community.
Would you like to upload a workflow that illustrates your issue? That could help and speed up the process.
