Code Node: Split string into array of strings
This should be a very simple issue, but I’ve been racking my brain on this for much too long. Below is the latest iteration of the function. I either get an error that the return type is not correct or I get “[object Object]” in my json.
Simple, input a string of text. Separate that text into an array of strings. Return the array.
Current implementation
const text = String($input.first());
const lines = text.split("\n");
return [{json: {output: JSON.parse(JSON.stringify(lines))} }];
Input
        "text": "Line #1\nLine #2\nLine #3"
Output returned by the last node
    "output": [
      "[object Object]"
Expected Output
        output: [
            "Line #1",
            "Line #2",
            "Line #3"
  • 1.91.3:
do console.log(text), make sure you’re correctly capturing your input, oh and console.log will show up in your browsers console so hit F12 → console → run code look for output
This should do it:
return [{
    json: {
        output: $input.first().json.text.split("\n")
You don’t need to stringify() and parse() afterwards.
This worked perfectly. I see I wasn’t drilling down far enough with the input parameter.
Thanks
