Code node stopped working in n8n Cloud — suspecting NODE_FUNCTION_ALLOW_EXTERNAL issue
Hi,
I’m using n8n Cloud (browser version), and recently my Code node stopped working.
It used to run fine, but now it hangs forever or fails to execute simple scripts.
I found this thread
where several users reported the same issue, and they mentioned it was caused by environment variables like NODE_FUNCTION_ALLOW_EXTERNAL.
Since I’m on the Cloud version, I can’t modify environment variables or restart my instance myself.
Questions:
Is there any way for Cloud users to reset or refresh their instance (like a restart)?
Could this issue be related to hidden environment variables or cached external modules on the Cloud backend?
Should I contact support to request a manual restart?
Thanks in advance for any help or clarification :folded_hands:
hi I was having the same issue if you contact your workspace owner they can update cloud version, we updated to 1.116.1 beta and it fixed the problem.
See: Update your n8n Cloud version | n8n Docs
