Hi there,
Having been away from n8n for half a year, I decided to go through the Documentation again … just to make sure that I did not miss any of the new functions. When I tried out the code from this example …
items[0].json.variable1 = $evaluateExpression('{{1+2}}');
return items;
… in the Code node, I got the following error:
ERROR: `items` is not defined. Did you mean `$input.all()`? [line 1]
But when I copied the same code into an old (/converted?) Function node, the same code works as expected …
What did I miss, or am I doing wrong and/or should I be doing differently?
