Combined expression help
Hi all - I have what may be a JavaScript question related to expression syntax. In my workflow I have three nodes:
  1. Extract event fields
  2. Find events
  3. Prepare data (an edit fields/set node)
In the last node, I want to set an expression that uses a value (fieldName) from the first node as the lookup value on the second node.
An example would be if the first node’s fieldName value = ‘Birthday’ then I want my last node to have a field that gets the value from the previous (2nd) node like $json.Birthday. It has to be dynamic though as fieldName will change with each execution.
In my head it looks like this, but I know the syntax is wrong:
{{ $json. + $('Extract event fields').item.json.fieldName }}
Any ideas on how I can pull this off? Can I do this in an inline expression or should I use a code node just before?
@hndmn , you could do something like this,
{{ $json[$('Extract event fields').item.json.fieldName] }}
Yes, thank you! I hadn’t considered using the square brackets.
