Community Node: Code-Mode Tool — 96% fewer tokens for multi-tool AI Agents
npm: npm install n8n-nodes-utcp-codemode
GitHub: mj-deving/n8n-nodes-utcp-codemode
Hey everyone,
I built a community node that changes how AI Agents handle multi-tool pipelines. Instead of making a separate LLM call for each tool, the agent writes a single TypeScript code block that runs all tools at once in an isolated sandbox.
Why?
Every tool call = another LLM round-trip carrying the full conversation history. With 5 tools, that’s 11 LLM calls with growing context each time. I benchmarked it:
Traditional (5 tools) Code-Mode (1 tool) Savings
LLM calls 11 1 91%
Tokens ~18,000 ~700 96%
Execution time 12.5s 2.5s 80%
At scale with GPT-4o pricing: 1,000 executions/day saves ~$15,800/year.
Traditional:  Agent → LLM → tool_1 → LLM → tool_2 → LLM → tool_3 → LLM → ...
Code-Mode:    Agent → LLM → writes TypeScript → sandbox runs all tools → done
The agent gets a single execute_code_chain tool. It writes the complete pipeline as code, which executes in an isolated-vm V8 sandbox with access to your registered tools.
Install
cd ~/.n8n/nodes
# Restart n8n
Then connect Code-Mode Tool (AI > Tools) to any AI Agent node.
Configuration
  • Tool Sources — JSON array of UTCP configs (MCP servers, HTTP APIs)
  • Timeout — Max execution time (default: 30s)
  • Memory Limit — Max sandbox memory (default: 128MB)
Good to know
  • Works best with Claude and GPT-4o. Gemini needs more explicit prompting to write code proactively.
  • Shines at 3+ tools. Single-tool workflows won’t see a difference.
  • Built on UTCP code-mode + isolated-vm for secure execution.
Would love feedback from anyone running multi-tool agents. Especially curious about results on longer pipelines or different LLMs.
Really interesting — and your benchmarks align with what we’ve seen in production.
We tackled the same token-bloat from a different angle: instead of a code executor, we reduced what the LLM sees to 8 domain facades wrapping 50+ MCP tools. Agent describes intent in natural language, facade translates it. Result: ~94% schema token reduction before any execution.
The two approaches are complementary rather than competing. Yours collapses the call graph (11 calls → 1). Ours collapses the schema surface (50+ definitions → 8). Combining them — domain routing into a code executor — could hit both bottlenecks simultaneously.
One heads-up: n8n’s native MCP Client has an active memory leak (#25740) that compounds under load. Worth knowing if you’re building on top of native MCP nodes.
Full writeup on our architecture (including stability tradeoffs): https://noyra-x.de/whitepaper/mcp-gateway-facade-pattern
