“Sign in with Google” is missing on the self-hosted n8n.
Same with Office 365 credentials, etc.
Or has it something to do with the self-hosted configuration? If yes, what do I need to be aware of?
Is this little difference (and others like this) somewhere described or compared between the subscriptions?
This credentials thing is because with n8n cloud you connect through the app that is configured by the n8n team. On self hosted you need to configure the OAuth2 app yourself, as you can of course not use the one from n8n cloud.
This is the case for all the OAuth2 credentials.
