Complete uninstall to fix update problems
I have moved my n8n instance to a Pi 4, it runs beautifully.
However, it refuses to update.
I run the correct pm2 stop, update n8n commands and it completes without errors.
But n8n is never updated, I am falling further behind on release versions.
So I have tried to uninstall using sudo npm uninstall n8n --global, which went well.
I then installed using sudo npm install n8n -g (if I do not use sudo, I get errors about folder permissions) and it all completed successfully.
Restarted pm2 and n8n, I am somehow still running the same poxy version that I uninstalled!
How can I completely remove n8n (but retain workflows and credentials)?
Many thanks.
Hey @britaliano,
This will depend on the full steps you took to setting up node and npm on your pi, If you used nvm then it could just be a case of n8n running under a different user so you would need to change to that user to then do the update.
If you run a ps -ef | grep n8n it should give a list of all the processes running and the user running it, As another possible test you could also run pm2 stop and check if you can still access it.
Thank you for your reply.
I bit the bullet, installed n8n using docker and it just…worked.
Fingers crossed it stays as easy as this.
Thanks again.
Hi @Jon , running into the same problem.
AWS with Lightsail
Running on PM2, with caddyserver
Currently on 0.202.1
node v18.12.0
npm 8.19.2
Updated node from 17
Then n8n refuses to update
When updated to v18 this log
root@ip-172-xx-xx-999:/home/admin# sudo n 18.12.0
installing : node-v18.12.0
mkdir : /usr/local/n/versions/node/18.12.0
fetch : https://nodejs.org/dist/v18.12.0/node-v18.12.0-linux-x64.tar.xz
copying : node/18.12.0
installed : v18.12.0 (with npm 8.19.2)
Note: the node command changed location and the old location may be remembered in your current shell.
old : /usr/bin/node
new : /usr/local/bin/node
Any idea on how to force this update?
Thanks!
Andres
Hey @pradilla,
That message looks unreleased to n8n and probably doesn’t matter too much, What I would say though is we support node v16 so I would use that just to be safe.
