Hello everyone,
I am quite new to N8N and I have a lot of troubles to make a simple Workflow that Get a Signed Document From Docuseal and then Upload It to kDrive.
My problem is that kDrive API request for the upload the size of the file, so I have to pass two parameters: size in bytes of the file in a query parameter and the file itself as bynary data in the body of the request.
Through browsing the multiple questions related to this issue on the forum I understood that to “bring back” the file as inputData and be able to call it I had to use “Merge” but it doesn’t work and I get the following error in the final http call to upload the file:
This operation expects the node’s input data to contain a binary file ‘data’, but none was found [item 0]
Make sure that the previous node outputs a binary file
"errorMessage": "This operation expects the node's input data to contain a binary file 'data', but none was found [item 0]",
"errorDescription": "Make sure that the previous node outputs a binary file",
"errorDetails": {},
"n8nDetails": {
"nodeName": "Upload_Signed_Document_To_Kdrive",
"nodeType": "n8n-nodes-base.httpRequest",
"nodeVersion": 4.2,
"itemIndex": 0,
"time": "25/04/2024, 19:14:05",
"n8nVersion": "1.38.1 (Self Hosted)",
"binaryDataMode": "default",
"stackTrace": [
"NodeOperationError: This operation expects the node's input data to contain a binary file 'data', but none was found [item 0]",
" at assertBinaryData (/app/code/node_modules/n8n-core/src/NodeExecuteFunctions.ts:1058:9)",
" at Object.assertBinaryData (/app/code/node_modules/n8n-core/src/NodeExecuteFunctions.ts:3712:6)",
" at Object.execute (/app/code/node_modules/n8n-nodes-base/nodes/HttpRequest/V3/HttpRequestV3.node.ts:1483:42)",
" at processTicksAndRejections (node:internal/process/task_queues:95:5)",
" at Workflow.runNode (/app/code/node_modules/n8n-workflow/src/Workflow.ts:1378:8)",
" at /app/code/node_modules/n8n-core/src/WorkflowExecute.ts:1050:29",
" at /app/code/node_modules/n8n-core/src/WorkflowExecute.ts:1726:11"
- n8n version: 1.38.1
- Database (default: SQLite): default
- n8n EXECUTIONS_PROCESS setting (default: own, main): default
- Cloudron Server
- Operating system: Cloudron Server
Thank you very much in advance for all the help you can provide
Best regards
