Concatenation of strings inside of a loop
Hi!
My main goal is to erase the names off a sheet that are also present in our HubSpot.
The problem arises when I try to “save” said names in a list that I need to send in an email at the end of the run. As you can see, I tried with a concatenation, but I can’t save the list, I can only see the very last name of the supposed list.
Any ideas of what I may be doing wrong, or alternatives that I can use to achieve my goal?
n8n version: 1.109.2
