Configuration issue
I am not able to create the any workflow showing connection lost on top right hand sight due to socket issue
pls let me know how to solve I do. the all possible solution still facing same issue
Error :
WebSocket connection to ‘wss://activepieces.brandintelle.com/rest/push?pushRef=fz2ixn0tfd’ failed:
Hi @Santosh_Yadav
Welcome to the n8n community :tada:
Where do you host your n8n instance?
Which webserver are you using?
