Hi there,
I’d appreciate your feedback on the best practices for using an external SQLite database. Specifically:
- Project Examples: Are there any SQLite implementations you’ve seen that stand out?
- Connection Method: What’s the most efficient way to connect to it (e.g., local, cloud-based)?
- Cloud Feasibility: Is a cloud-hosted SQLite solution viable for performance/scalability?
Thanks in advance for your insights!
